1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc.
Office work, with the caveat that this user tends to wind up with a blue million processes running in the background. antivirus, picture software, blackberry software, etc etc.
2) What's your budget? Are tax and shipping included? Unsure, say around 900?
3) Where do you live?
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific. I have some spare cases laying around. And he has a decent monitor, so everything But that.
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model. just the case. and monitor
6) Will you be overclocking? No
7) What size monitor do you have and/or plan to have? 22" at the moment.
8) When do you plan on building/buying the PC? Unsure again, he's just starting to look because his abused laptop is rebelling.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc. no need for firewire or SLI/Cross, raid possibly if I can talk him into a mirror.
10) Do you already have a legit and reusable/transferable OS key/license? Yep
I'm thinking of a budget i7 build, not because he actually uses it enough to warrant an i7, but because he abuses it enough. At last check I think he had some ridiculous 150 processes running on one of the ultraportable lenovos. And thats after he's started trimming down. Telling the gadjet ridden CEO that he's a goober and should have an abacus at max isn't a good idea. Which is what I'd like to do.
So I'm thinking the i7 2.66 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
a 6gb ram kit http://www.newegg.com/Product/Product.aspx?Item=N82E16820231223
some random cd/dvd burner http://www.newegg.com/Product/Product.aspx?Item=N82E16827106327
2 of the 750 gb wd drives (if I can talk him into a mirror) http://www.newegg.com/Product/Product.aspx?Item=N82E16822136359
pc power and cooling ps http://www.newegg.com/Product/Product.aspx?Item=N82E16817703017
el-cheep 4650 http://www.newegg.com/Product/Product.aspx?Item=N82E16814131133
and this board to tie it all together. http://www.newegg.com/Product/Product.aspx?Item=N82E16813128375
I'm sure it's way overkill, but I really can't stress enough that he doesn't have any sense when it comes to taking care of his box. And I'd rather have something that will run all his crap with room to spare so I don't have to go finger around on it every other day.
I don't know about those 2 drives. Don't the wds drop out of the array unless they're the raid editions?
