Looking for thin fans
  • Thread starter Deleted member 88227
  • Start date
D
Guest
I am looking for a 80x80 mm fan that is no thicker than like 15mm, 10mm would be prefect. Doesn't have to move that much air, just some.
Low voltage too, less than 12V. Thanks!
Connector does NOT matter. Just need two leads.
I've been looking through newegg, but they have so many fans and I have to open each fan's description to see the height and some doesn't show.
Wow thanks, you obviously know your way around newegg better than I do. Thanks a lot man!
