Looking for RAID card recommendation
t_ski
I'm upgrading my home server (WHS ver 1) to a new OS and new hardware, and I would like to invest in a decent RAID controller. Here's what I'm looking for the controller to support:
1. OS will be Windows 8.1 or server 2012 R2 (R2 if I can get a key)
2. I plan to start with three 3TB Hitachi SATA3 NAS drives
3. Must be able to do Raid 5
4. PCIe card (up to 16x)
My budget is $300 max. I don't mind a SAS card with a breakout cable, but I'd like the cable to be included in the kit. A BBU is optional, as the server has a UPS that it will be plugged into. It would be great to find an 8-port card for that price, just in case my needs grow over time, and I could add more drives or build a second array.
Thanks in advance for your suggestions :)
Plenty of good LSI cards that can be had for that budget I think. Areca too if you don't mind getting one used.
If you want to buy new, a 9240-8i is an option.
If you want high performance you should get something with onboard RAM like the LSI 9260/61/65/66/70/71.
I got a used 9271-4i for ~$150$ a while ago.
