- Feb 4, 2007
I am looking for skinny led wire something like the picture below. If I can get it in different colors that's a plus. Also whats a good gauge size for LED wire?
20-26 guage wire is good for a single LED. Go to radio shack or Home depot and buy about 20ft of their speaker wire.
Almost any speaker wire will power a single LED without question... They also come strapped together, making for a very clean and easy cabling job.
Wouldn't speaker wire be harder to solder then lets say straight cable wire?
Not to be an ass...But define "harder to solder"... I am in no way a "solder master" but as long as the wire is more than 12-15 gauge I find it easy to tack it together... you might want to grab some of that "de-soldering" braid from radioshack just in case you do mess up.
That stuff works miracles 'yo.
The only real solder I've done is mod-chips to xboxs and I used single strand wire for that. I just thought using multi-strand the strands would want to fray out instead of (single stand) just connect one end to the other and BAM! You bust on a towel and take a nap.
Big black wires hurtJ/K
