Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I need to add a fan inside the case to cool a tuner card. Are there any brackets that would allow to add a fan on top or near the card? Something like the discontinued Zalman FB123?
On one of my cases I took a short piece of aluminum angle and drilled some holes in it lining up with holes in my case. Then I drill two holes to line up with the screw holes on a 120mm fan. It was solid with no vibrations that I could detect. It blew cool air across my video card and northbridge cooler which helped my overclocking a lot. If you can find a couple screw holes anywhere on your backplate- or basically any place else you can do this very easy mod with just a hack saw and and a drill. Almost any hardware store will have some aluminum angle.
