Looking for a weird tuner system... need help!
Tengis
Im trying to piece together a system that will support anywhere from 6 to 12 TV tuners.
Let me tell you what its going to be used for:
Going to have a total of 12 VCRs playing tapes back that recorded information from fighter jets. The information needs to be viewed in a fashion similar to what a surveillance system does... the sources need to be viewed in a grid pattern (where you can see them all) with functions to enlarge one screen or possibly even manipulate each screen size individually with the ability to record to the hard drives.
Ive figured up a quote with Hauppauge dual TV tuners (two in one PCI slot) for a total of 6 tuners per system and 12 total (on two systems). I'm almost set on sticking with 6 tuners per system because there are 3 tapes per jet that need to be viewed... which means 2 jets on one system and 2 on the other.
My only problem is the software. Supposedly I can get a version of Beyond TV that will support 6 tuners but it doesn't have the functionality to manipulate each source individually (or anything similar to a surveillance system).
If I wanted to go with a surveillance system then I don't believe I can get one that will accept inputs from a standard VCR... or any type of capture card (Geovision, etc).
Any suggestions? Ive got all of the recording stuff figured out... raided hard drives are a must... its just a matter of software. :(
Im looking into possible options of different tape players that will output in different formats (Firewire or something) and then maybe it will open up other options rather then TV tuners. :confused:
