Looking for a USB Adapter
macrospect
I will pay the person who finds me a cable with this kind of end $7 in their PayPal account.
Long story short, I messed up the USB adapers on the front of my CM Stacker STC-T01 case. On one end of the cable it has USB connections which look like this:
On the other end there are standard USB header pins which look like the following cable:
http://s170.photobucket.com/albums/u265/rrdizon/HP Case/?action=view&current=IMG_0190.jpg
If they don't exist then can someone please tell me what the hell type of connector that little one is. :confused:
Again if you can find me a cable with the header on one end and the white 8-pin on the other (ie. the one which the CoolerMaster supplies with their front pannel) I will be willing to pay you $7. If any of you have some of these I will be willing to purchase them from you.
Thanks!
I really did not mess up the ends but rather tried to cut the cable in half and splice the cable with another cable (I will take some pictures later to explain what I am doing). I am not that satisfied with the job which I did on the splicing so I am rather looking to replace JUST the cables and start fresh (note: splicing USB cables is a major pain in the ass). I would order a new module from CoolerMaster but they said that the next time they will have them is in the end of this month at the earliest and I really only need the cables in the first place.
So I am stuck now with finding a cable which has the white connector pictured above on one end and a 9-pin USB header plug (see the link in my first post) on the other.
Again, the $7 is still there for anyone who can find this type of wire for me (or maybe I will just round up and make it $10 ;) ).
Ideas? Sources?
While waiting for a better reply, look through the digikey catalog. They have those connectors, I'm sure, because I've used them before... you just gotta search. ;)
