I'm playing around with winscp and it looks like I cannot open two remote directories together (I want the them shown side by side)
is there any other app I can try that will do this? Thanks
btw I'm using xp locally and these are linux remote servers
Just ssh into the server and use midnight commander. The default view in midnight commander is a side-by-side 2-paned view.
EDIT: I should clarify that you can display remote directories over ssh in the panes in mc. So when you're running mc on one server, you can have one pane show a local folder and the other pane show a remote folder on a different server.
