Slartibartfast
- Sep 25, 2004
Hey all, I'm just starting to research my first watercooling project, and I'm hoping somebody can point me in the direction of a good radiator. The problem I'm having is that the only viable place in my case (silverstone TJ07) to mount it would be on the back, where there are two 92mm fans. It seems that the only 92mm radiator in existence is that thermochill one, and there aren't even any on ebay. Are there any good options for me or should I start looking for a new case? Cutting/drilling isn't much of an option, esp. since the whole top of the case is pretty much unusable. It has this mesh cage with 2x 120mm fans in it, but it's designed in such a way that the fans attach to the bottom of the cage, not the case. If I were to take the cage out, the hole in the top is too wide, so a 120mm fan would just go right through it.
