Looking for a Motherboard
mizer
First post ever here, be gentle. I am building a new PC and I am looking for a good reliable motherboard. I have looked everywhere and read everyones opinions, but I want more. I am going to be running this processor:
AMD Athlon 64 X2 4400+ Toledo 1GHz FSB 2 x 1MB L2 Cache Socket 939 Dual Core
Not sure on a video card either, I want a video card that will play F.E.A.R. and Quake 4, etc... I want something that will support SLI even though I won't be going SLI right away.
So please recommend away. Also if you want to recommend a good video card go right ahead, it will save me writing this in the video card section :)
As always thanks in advance.
7800GT(BFG or Leadtek[funkiest brands]) and a DFI - NF4 Lanparty UT SLI-D sound perfect for you.
7800GTX is awesome too but might be abit too pricey, im not sure bout your budget reqs.
Lachesis, ZOMGWTFBBQ:
I appreciate the input, Lachesis thanks for the link to the motherboard.
ZOMGWTFBBQ - Do you have an links to the video cards and/or motherboard you recommended? (Maybe some newegg links?)
Yeah the GTXs are probably to pricey for me at this point.
Bump, looking for more input please.
Also is this power supply good for an SLI setup?
OCZ PowerStream OCZ520ADJSLI 520W Power Supply
The powerstream is an excellent powersupply, and anything over 500 is good for anything a normal system could need.
As for the videocards, eVGA has a really nice warrenty, and has a stepup program, which gives you decent discounts when you upgrade from one generation card, to the next.
eVGA
Asus is also quite good, but i have never used them.
ASUS
Ok so here is my build so far:
Maxtor MaXLine III 7L250S0 250GB 7200 RPM Serial ATA150 Hard Drive - OEM
XFX PVT70GUDF7 Geforce 7800GT 256MB GDDR3 PCI Express x16 Video Card - Retail
CORSAIR XMS 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory - Retail
Again just looking for recommendations on a motherboard. Everytime I think I have found one, I start reading the reviews and start to rethink about buying it. Going to go SLI in the future. I almost bought the GTX 512MB video card, but $749 is a lot to pay for a video card.
have you bought all of the parts yet? if you havent, reconsider the Corsair ram and look into the Muskin Redline series, or the OCZ GOLD VX series. Those two rams have almost identical overclocks, and they are some of the best ram on the market, when not overclocking.
As for motherboards.. Are you planning on overclocking, or not?
If you are, the DFI Lanparty series boards are the best overclocking boards in the world (at least, one of the best) They can be unstable sometimes, but if you are good with them, and have patience, you can achieve some incredible overclocks and a very stable system.
If you are not overclocking, look into the Asus boards, aside from the A8N32-SLI Premium boards, are as stable as a rock. the A8N-SLI Delux is really good.
