Looking for a case
sam600sx
Hey everyone, As the title says I am looking for a case for my nephew who works as a recreational vehicle tech. The case is located in the repair shop. As you can imagine the environment is extremely dusty and dirty. looking for a case with air filters which are also easy to clean. It also needs to support a 3.5 external drive as manufacturer's often send program updates on floppy drive discs. I must say I just spent most of the day pulling apart his computer to clean all the dust out of it. NOT FUN!
Case mod gallery was not the right place to ask this, but I will answer anyway.
Phanteks Enthoo pro will be a good choice for you. You might also be able to use the Enthoo Pro M, its much smaller version better internals though and less expensive, both have filters on all intakes
Your right about post it case mod gallery. I didn't mean to put it there. Thanks for the suggestion though.
