so i've been using a microsoft intellipoint 3.0 for a long, long time now and i thought it was a good time to upgrade. i decided to bite the bullet and get a logitech mx518 because it was new on the market and targeted toward gamers--not to mention that everyone and their mother said it was the mouse to own. it also has the two buttons above and below the scroll wheel, which i thought would be handy to scroll through large documents, which i do frequently when surfing the web.
installation was pretty simple. i installed the setpoint software that came with the mouse and went in to customize the buttons. the two left buttons are back and forward--good. the two buttons by the scroll wheel are sensitivity adjustments--hmm, better change that to scroll buttons. done.
i go to surf the web, and forward and back don't work. --cursing ensues-- i do a quick google search and find other people have this problem too. so, i'm forced to set those two buttons to a key combination of alt+left and alt+right. ok, no biggie.
i then startup farcry. my previous settings for the two left buttons don't work. so i go to the key config and redesignate the functions of those two buttons. they show up as "alt". presumably this happens because of my previous key combination settings in setpoint. regardless of this weirdness, they do what they are setup to do in the game.
doom 3, same problem. i redesignate the buttons, and now it does the function i want (switch to flashlight), but at the same time it strafes left. --more cursing-- getting very frustrated. ok, i'll switch the flashlight to mouse 3 (pressing down on the scroll wheel). nope, that button doesn't even work in the game.
are other people having this many problems getting their mx518 setup the way they want? am i missing something blatantly obvious here, or is this thing leaps and bounds behind microsoft in terms of setup and compatability?
