Nexrus said:I just bought this exact fan and it has two hook ups.. the one circled in green and red. Do both need to be hooked up? I hooked up the green one and it turns. Any help is appreciated. Thanks
Then its just a fan speed control wire. You can hook that 3pin header up to the mobo (it will still be getting power from the 4pin molex) if you want to control it via windows with speedfan, etc. Its optional.Nexrus said:There is only one single wire coming from the red circled connnector.
thrawn86 said:Does the 3pin header have just one wire coming out of it, or three? I can't tell from the pic.
Sometimes a fan will come with a normal 4pin molex and a 3pin header with just one wire (mobo fan speed control) that is optional. Sometimes that 3 pin header can also power the fan, and they're just giving you the option of where to hook it up.
Nexrus said:Ok, Im sorry but Im having a little trouble understanding. Do both have to be hooked up? or need to be hooked up?
Arcygenical said:No.
If there is only 1 single wire coming from the 3 pin connector, it will NOT power the fan.
It is ONLY the tachometer (rpm sensor). You NEED the molex to give it power, and the 3pin to sense RPM. period.
Blue Falcon said:<cartman> NOT SPEED CONTROL GODDAMMIT! (><) </cartman>
It's the rpm sensor wire.
Basically when you get a fan configured like this you connect the large 4-pin molex to your power supply, and then you can OPTIONALLY plug the small 3 pin connector (the one with the single wire running to it) into a fan header on your motherboard. This will allow you to monitor the fan RPM via your motherboard's BIOS (or a piece of software that will read data from the sensors like MBM or speedfan). This configuration does NOT allow you to control the speed of the fan - simply to monitor it.
These tend to throw some people off because they see that single rpm wire and 3 pin connector and don't know what the heck to do with it.![]()
