nameless_centurian
- Apr 4, 2003
what's up, people?
i'm totally new to the linux and unix world, but i am learning. while i am nt new to computers in general, i posess only a basic knowledge of them, so please realize that i can edit scrits, etc...but can not write them (unless instructions are provided)
okay, so here's the deal.
i want to set up a router/firewall/nat box. i know enough about networking to be able to follow the howtos and get it done (i am also CCNA), so this is not my current problem.
right now, i have 2 nics in my linux box (i am actually writing this from my linux box, so it does work!). i am using vector linux, based on slackware and the 2.4 kernel. upon bootup, the kernel locates my eth0 (which has no cable in it right now) and tries to DHCP it. it finds nothing because there is no cable, no problem with me...
but it does not find the 2nd nic. i edited my modules.conf file and told the kernel what module to use. so after it boots, i can use dhclient and eth1 configures properly, in fact i am writing this on it as i mentioned earlier.
i looked at another howto and it says this:
By default, the Linux kernel only probes for one Ethernet device. You need to pass command line arguments to the kernel in order to force detection of furter board
can i edit the netdevice script or something to bring eth1 up at boot after eth0 is brought up?
thanks for the help.
