Italiano86
- May 26, 2008
I noticed that there seems to be two ways to mount the mobo into the case. There are 6 stand-offs which go directly onto the mobo, and 8 holes for the x-clamp screws after everything is in the case.
My only concern is with the x-clamp fix you no longer have those 8 screws to hold the board down, and hopefully the stand-offs will be enough. Planning on doing the x-clamp fix to my falcon board anyway to keep the mobo from flexing and ruining my 2nd 360...
