Lian Li V1000 Power Button problems...
MadAsHeck
I did a little cable re-organization in my case and now it seems my power button does not work. I've checked to make sure the cable is connected to the motherboard correctly. Luckily I have a DFI Lanparty UT SLI-Dr so it has power and reset button built into the board, but its a pain to keep opening the case to turn it on.
Anyone know of any ways I can check or fix the power button?
Get out a multimeter or somethin and check if the wire is still intact, I've had a lot of problems with the lights and power button wire connections breaking in my v1000
