EnderXC said:Just a quick question of the PC6x cases:
Does the bottom hard drive cage slide out away from the case?
Thanks guys.
[EDIT]: Where is the cheapest place to get them?
Dillusion said:Yes on the 6X Series it slides out towards the windowed side, on the 7X Series only the 'Plus' Series slides off.
Thanks guys.
ninethreeeleven said:I cant be totally sure but if you buy a new sidepanel (aftermarket) the one that is designated PC-61 will fit all PC-6X and all PC-7X. I have read this on numerous sites and the measurements seem to fit.
Also, I have the PC-7b from newegg (no longer for sale) and I pulled out the lower HDD cage. I reversemounted my drive in the 3.5 bay.
the pc-7x means pc-70 (the big one) and its varients. the pc-7(b) is the budget version of the pc-6x. it has no removeable motherboard tray, no fan speed controller, and a different HDD cage. (3 drives instead of 5 or w/e the pc-6x has, mounted horizontally instead of vertically like the pc-6x)ninethreeeleven said:I cant be totally sure but if you buy a new sidepanel (aftermarket) the one that is designated PC-61 will fit all PC-6X and all PC-7X. I have read this on numerous sites and the measurements seem to fit.
mwhahaharogue_jedi said:the pc-7x means pc-70 (the big one) and its varients. the pc-7(b) is the budget version of the pc-6x. it has no removeable motherboard tray, no fan speed controller, and a different HDD cage. (3 drives instead of 5 or w/e the pc-6x has, mounted horizontally instead of vertically like the pc-6x)
mwhahaha
n64man120 said:So awsome to hear you say that cuz last week I spent 2 hours deliberating and ended up picking that exact one.
mwhahaharogue_jedi said:i just wish i could get my hands on a new sidepanel for my pc-7. i know sotrick sells them, but i gotta get the $20 and a CC first. heh
mwhahaha
mwhahahan64man120 said:Yes, but in black, and it's for PC-7. Are they the same sidepanel?
This is the same side panel that is on the PC-65. It will fit the following:
# PC-7
# PC-60
# PC-601
# PC-65
# PC-67
# PC-68
# PC-82
ninethreeeleven said:There you go, thats from their site.
