Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have the Lian Li PC 65 and it came with 4 80mm. They are a little too loud for me and I'm wondering if I could put some 120s in it to quiet my pc down, is it possible? Thanks
My sig is my first build. I took out the stock fans and put in some much quiter Enermax fans, with the plan to get a fan controller, like the Vantec Nexus, sometime later. The intake fans have the speed control, but the two exhaust don't.
120mm fans would be a pretty extensive job. You could perhaps start with modding another 80mm in the rear under the existing one. I've read that another 80mm will fit, but I don't know personally.
There are very quiet 80mm fans with good CFM. My two intake fans in the front are very quiet even with the speed control on the highest setting.
