Lian li PC65 vs PC60+
Metaball
Ok, here is a strange one..
I work at a online computer hardware place in Australia.
So I try get the order manager to bring in a Lian Li PC 65 from the main warehouse and it shows up as a 65+ with a seperate side window straped to the box...
So now back to my main question, Does PC65 have anything major over the 65+ or viceaversa? AFAIK it is the same dimentions just with a diffrect front plate and using 120mm fans instead of the 90mm(??) fans on the PC65.
I plan to stick a watercooling rig in with at least VGA and CPU waterblocks.
Am I totaly looking at the wrong case or should I push for a PC65, or settle with the PC60+.
Thoughts/Tips/Past experience greatly apriciated.
Thanks a lot in advance (wont beable to reply untill work tomorrow, internet down at home )
The only physical case difference really between the 2 is that the Plus has the 120mm in the front. If you're going to watercool, that would be a better choice as you wouldn't need to mod anything as much to put a single 120mm rad in there. The PC 65 has the 2 80 mm fans and I believe may need to be modded to fit the height of a 120 mm fan. The Plus also comes with a duct for the rear fan and an additional fan attachment to draw air out the back of from the videocard area.
Also, the PC-65 has 3 3.5 bays in front where the PC-60 Plus has only 2 due to the 120 mm fan height in front.
PC-65
http://www.newegg.com/Product/Product.asp?Item=N82E16811112024
PC-60 Plus
http://www.lian-li.com/Product/Chassis/M_C_PS_PC-60.htm
Go for the 60+, i have an old 61(black 60) and had to mod it to fit two 9 cm fans because it needed a too cruel mod to get a 12 cm in there,
And you can allways buy a window panel,
