THEnumber337
- Feb 21, 2007
I am looking into buying the Lian Li PC-7B Plus II case right now. I already have the PC-v1000B case but it's a little big for my needs and I would rather have a smaller case. My question is how much room is there behind the motherboard tray and between that side panel. If I get this case I want to cut some holes in the motherboard for more efficient wire management. Is there enough room to hide the 24 pin power connector cable behind it? That's probably the biggest cable that I have so if that can easily fit behind it everything should be okay. Also, anyone who has this case and has done some wire management with it could you please post some pictures? Thanks. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
