Lian-Li Flathead Rivets
BellaCroix
Okay, placing an order with McMaster-Carr tomorrow for random bits and pieces I need. Anyone know the exact dimension on the flat head pop rivets used on the Lian-Li v-series cases? They use plenty of the round head ones but throughout the case (especially on the side rails) they use a flat head rivet.
Tried replacing them with rounded head rivets but then the sides don't fit on correctly so it looks like I'll need to order them.
Thanks in advance!
