Lgl203wtx 20.1
Granthos
does anyone know anything about this moniter like what panel it is ?
http://www.newegg.com/Product/Product.asp?Item=N82E16824005070
i was looking aroudn on newegg for 20.1 WS just to check so i could make sure that the view sonice was the best, thne i cam across this and i am thinking more and more that i would like to have this more then i would the VS, 1 it is a bit cheaper without the rebate hassle, 2 it has a 1400:1 contrast ration :eek: crazy good and i like the style the same if not more then the VS, this summer i might this one instead of the VS but i need some opinions.
It's a TN panel. Slight banding with DVI, no banding with VGA connector.
There is a thread over at widescreengamingforum.com about this monitor.
cool i coudlnt find it but i will go look again
and thanks for the info
edit: if thisthis
is what you were talking about that is the straight wt not wtx i think the wt is the same size, but it is way to expensive.
I found it by accident. The thread over there does not have the "x" in monitor name.
ya i figured that one out ;) no prop, they around the same moniter my guess, but the wt has a load more features, but for me i wont be using them ;)
