LG 204WT Help!
topslop1
I just got this montior tonight from a local Circuit City. The monitor was working fine and then after about 10 minutes of use it just shut off. I turned it off and then turned it back on again and then it proceeded to work. Not another 2 minutes later the same thing happens. It keeps doing this and if I try to turn it off and on quickly then it won't post my computer screen. When I give it a few seconds and then turn it on again it works fine. The whole time the power button is lit up.
Could this a bad CRT connector cable that came with the montior?
or
Is my computer shutting the montior off somehow with a driver conflict?
