Soarin
- Jul 23, 2010
Okay after trying sketchup for the first time, or any cad program. This is what i would like to build with tweaking left. Just trying to figure this out. Also the downside is i would have to also take the dimension to someone and have them cut and bend the parts for me because i do not have a bender or anything.
By bigdaveberg at 2010-12-22
[/URL]
To give you an idea the cap toggle switches control the cold cathodes, i will more than likely add enough switchs for each cold cathode. The push button switch is for the on/off and reset. Which the little silver plate under them will say "Deploy" "Re-Deploy". The top peice has a litttle dish, that will be my wifi dish. The dish is on a vent that will be the exhaust uptop. And yes that is a cupholder. I have cold cathodes inside the case next to mobo tray and near the rear 120mm fan and up front in the front cupholder round section, one up in the vent(lookng to move it back) and the last CC under the optical drive bay which is represented by black boxes the same size as drives.
And the black area is a hinged side panel so that i can do wire management on the side panel without the window. I also have cut out in there but are unable to see them due to black inside.
This is a start and i do not know when i will start this because of resources. I will be getting the dimensions and calling around.
