Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Looks nice lemmy I especially like the way you got the grill to fit on the top. Where's the Aquaero? I only see an Aquastream controller and a Creative control center...
They are vibration absorption mounts. You use them to attach the pump to, well, whatever you're attaching it to. You'll notice if you play with them that they are VERY flexible... it's supposed to act like a shock absorber to keep the vibration of the pump from being transfered to the case.
I need help installing the Cuplex XT on a DFI lan party nf4 ultra mobo, do i need to keep that yellow support braces around the processor? or can i just do it without the support braces
I just ran into another small problem, a tube is too short and is bending slightly =/, i already filled the system up with liquid toO!!!! do i have to redrain everything??
