legacy ports
do you use legacy ports on your motherboard?
  • yes
    Votes: 17 33.3%
  • no
    Votes: 34 66.7%
  • Total voters
    51
(cf)Eclipse
Freelance Overclocker
poll says it all. if you do use one or more, please post telling us which one you use.
yeah, i guess i should have defined legacy ports. i'd call the printer port legacy though, cause my current printer/scanner is usb :eek:
then yeah, i do... although i do think that com ports should go the way of the dodo... i havent used those in years and years
laser printers are expensive so we're hanging on to the older HP we have, it doenst have a USB connection. all our other printers are USB tho
edit: damn, ps/2 is legacy now too? all my mice and keyboards are PS/2 so i guess im a big user of legacy ports :p
I occassionally use the PS/2 ports on my computer when I have it out working on it. Otherwise, everything I have is USB...
PS/2 isn't really considered legacy. Legacy is primarily like the serial and parallel ports.
At home I don't have any hardware that uses them anymore. I have a dot-matrix somewhere but it's been mothballed for a few years now. Where I teach, we're involved with the LEGO mindstorms robotics program and the transmitter tower requires a serial connection.
Cheers!
iamthedruman
for home use, other than the ocassional ps2 only keyboard i dont need any of my legacy ports, usb all the way..
for WORK use, without those legacy ports we'd be scewed. There are many parallel printers in use, many devices that use the com port even and almost all machines use ps2..
At home, NOPE
At work, YES, I actually have a total of 6 serial ports in my workstation for RS232, DNP, and serial MODBUS protocol communication with industrial devices...
MD
PS/2 -> keyboard, trackball
COM -> UPS
LPT -> laser printer
USB -> only a scanner which I use occasionally. I did have the trackball connected to USB for a while, but moved back to PS/2 because it's more convenient.
NoGodForMe said:
Yes. Even use a floppy and I'm proud of it.
yeah, so do i actually. i'd ditch it if i could make my usb drive emulate a floppy though, but for the time being it's there. and i don't consider it legacy, because it's still widely used
streetkid said:
oh ps2 is legacy? ps2 is superior to usb
i dunno about it being superior, but since many new keyboards and mice are sold with ps/2 ports, i wouldn't call it legacy either. *shrug*
Serial port for console port config of routers and switches. Used to use parallel port, but got an old HP network print server adapter for free. Also using both PS2 ports.
Nope I don't use any legacy ports on my motherboards. I see them as a resource hog of the isa bus, so I disable them.
I have most items running through the usb ports including my keyboard and mouse. All except half of my systems use a kvm switch which do use the ps2 ports.
technically, legacy ports are defined as (these days)
COM (RS-232)
LPT
analog audio (headphone jacks)
PS/2 (both mouse and keyboard)
MIDI/Gameport
PATA
Floppy
Personally, I still use the following:
COM (only one) -- programming my CPLD and FPGAs
LPT -- printer
analogy audio -- speakers and microphone (for real-time signal audio analysis)
PS/2 keyboard -- programming CPLD and FPGAs
Floppy -- gotta love the good ole boot disk
While I certainly love the newer interfaces (USB, FireWire, et al.), i don't think we'll see the others like COM and LPT go anywhere any time soon since they are so well document and supported *in hardware* via dedicated interrupts.
COM (RS-232)
LPT
MIDI/Gameport
PATA
Floppy
LPT -- printer
I voted no, but forgot about internal floppy port if that counts, and also only considered my main PC.
Main PC: No unless floppy drive counts, still like to flash the BIOS that way, and both PC's have a RAID array, if I do a reinstall need the floppy for that...and no, I never made a Windows CD where it has the SATA drivers on it also. That and I like to run Memtest via a floppy if I try a new overclock.
Spare PC: Still using PS/2 Keyboard & Mouse on it, and floppy.
Don't use LPT or COM ports, even have them shut off in the BIOS on both PC's.
All of my optical drives are PATA, there aren't a huge number of choices for SATA optical, and they tend to be pricy still.
You're not including AGP and PCI slots in the legacy list?
According to today's environment, no. that is, unless you want to split hairs about PCI-16, PCI-32, and PCI-64. However, ISA and MCA slots are definitely legacy among the expansion ports, but you don't actively see them on motherboards anymore. Likewise, you don't see AT power connectors, only ATX.
And the move is on to 24 pin vice 20 pin, as we speak.
I was only a little tongue-in-cheek, because of the PATA classification as legacy. I don't see PATA going away any time real soon. At least not until they start cranking out some PCI-E boards with PATA plugs, similar to the old RAID cards we had to use before on-board RAID.
I use a serial port for my UPS, and on occasion to sync up my Blackberry. I also use my PS/2 keyboard port, even though my keyboard could use USB.
hmm, seems like more people use legacy than i thought..
good stuff to know
(and yes, this is a bump for more results ;))
the only ports i use are USB (like 6 of em), VGA (soon to be DVI when i get a new lappy), and standard audio ports (mic and headphones. mic soon to be USB, and headphones soon to be S/P DIF)
