LED screens & more
thejawn
The LED screens that are on the front of some PC cases that have words and such on them, what are they? How do you program them? Where can I get one? I'm planning my first PC mod and I think that it would be cool to have one of them.
Also, I have some spare LED lights, and I want to do something like this but I'm not sure where to hook up the wires to, and where to get a resistor from.
Another part of the mod I am doing will be including adding a fan on the face plate. The plate is about 4mm thick. The hole I need to cut is around/about 6cmx6cm, what tools should I use?
Another question with LED's is that I want to add a few into the PC design but I'm not good with electrical wiring and such.
Any help is appreciated.
1) The screens are commercial solutions that interface with either a VGA port, USB port or Serial COM port. Matrix orbital, LIS, Aqua Computers are some suggestions... jab-tech sells a lot of them, as does xoxxide.
2) You'd hook the wires up to any available 5v lead on a Molex connector... You'd want 4 resistors, 1 to each LED... And you'd run the LED's in parallel. The resistors you'd need are 68ohms rated for 1/4w.
3) What's the face plate made of?
4) Guide to LED's ;)
Thanks, I'll try to understand that :p.
The faceplate is plastic, I'm working with the LEDs now.
