i think u gotta do it in parallelOriginally posted by alphanumeric
If you wire them all in series and get the polarities correct it will work.
take all the positive leads from all the leds and solder or wire them together... do the same for negative leads... that way you have combined 6 positive inputs and 6 negative outputs to only one positive input and one negative outputsOriginally posted by Xandas
How many should I re-lay to one Connector? they at 2V each.. also I have resistors but they are like 420 OHMS... How should I connect to the powersupply? help![]()
