LCD under $250
Hello, I would some input, on which is the best possible monitor I can get for under $250. I am a Gamer and would like 1680 x 1050 resolution.
I am looking at This but with all the commotion about the A,C,S models or w/e I don't know if I should get it.
Thanks every one
That's not under 250$, but it looks like a great monitor, 2ms? wow.
Acer AL2051W
Shipping may put you a little over budget though.
Edit: Then maybe the HP w2007.
I don't really want that Acer b/c it has an older panel in it. Not saying that its bad but I would like to buy something that is relatively new.
My only advise is that you really can't go wrong with a samsung panel, they are awsome tvs/lcds.
Just stick with the Sammy and you will be straight, or you can see if you can get a Dell 2007FPW used, you can't go wrong with the Dell or any Sammy!
BTW I am fairly well researched on LCD panels, so if you have any questions, just PM me.
I just picked up the HP2207w for $289 plus tax. Just check the hp2207 thread close by...for the extra $40, its well worth it imo.
