computerdude
- Jul 14, 2005
I just picked up a 19" Sony Multiscan G400 Trintron True Flat CRT real cheap with warranty. Is this monitor comparable to a LCD monitor in graphics and performance. LMK. Thanks
ellover009 said:CRT will always violate an lcd, but lcds are getting there slowly to match crt. One advise on the triniton display, when u have a white background and the screen is nicely warmed up you will see a tiny vertical line. it holds the matrix together. slightly annoying but best CRT tech. Where did u get it n how much u payd 4 it?
TechStuey05 said:That's a great crtIt really depends on the type of lcd that you're comparing it too. but for the most part unless your're comparing it to a top of the line lcd, graphics and performance wise that monitor will beat out most lcds.
