Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
yeah, i have the L.I.S. lcd screen and love it. you can see pics of it in my post "new h2o rig finally setup.... woot!!! Here's Pics". it has an auto fan controller than reads temps from mbm5 and will automatically adjust your fan speeds for you, plus its a breeze to setup. i highly recommend it, especially considering it only cost $70-$100 depending on where you find it. i have the "blue eye" version which is cheaper. the VCD display models are a bit more expensive but are suppose to have a brighter display...... i dont see why they need to be any brighter.. mines plenty bright. anyhow hope this helps, and gives you another option compared to the crystalfontz, which im not too impressed with.
