LCD Color Calibration?
I've got a NEC MultiSync 90GX2 monitor and the colors aren't accurate. I've used Adobe Gamma but that really just adjusted the brightness/contrast. Is there a program I can use that will help me get the colors to be correct?
Thanks.
This company is what Gateway included with my fhd2400 I like it and it does improve the monitor alot. Its strickly an eyeball type program ( Meters) involved. I feel it does an excellent job with Gamma, Brightness, and contract. Colors appear to be good overall.
I've had a lot of success here.
Do be aware that you may need to raise or lower all of your RGB chanels to get the best all around brighness and contrast out of the panel. Then just dial in the relative adjustments between each RGB channel. If you can't find great success, check if your panel is TN. If so, you will likely not be able to achieve great color quality. (Just from my experience)
That link worked really well. Thanks :)
