May 15, 2005 #1 O oceancyc Limp Gawd Joined Jul 9, 2004 Messages 497 Is their a program to make a shortcut so that I can launch multiple programs with one click from my Quicklaunch taskbar? And is it possible to create a delay between launches throught the shortcut?
May 15, 2005 #2 B broekage Limp Gawd Joined Dec 21, 2003 Messages 176 You can make a batch file that launches more than one program, and then put a shortcut to that file in the quicklaunch. example: open notepad and make a new txt file. put in it something like: "C:\Program Files\Program 1\file.exe" "C:\Program Files\Program 2\otherfile.exe" and then save the file as whatever.bat when you click the bat, it will run both of those programs. this does not use a delay. PS. you need the quotes if the filename has a space in it.
