I should read my post be for I hit submit.
What happened to my first reply in this thread?
Why? It is not an advantage that a gas engine runs at higher speeds. It is a disadvantage that a gas engine cannot make the same level of power without being run at that faster speed. Fuel efficiency decreases and engine wear increases as rpm increases.
Dual plug is used because the flame can't travel fast enough from the point of ignition so some fuel far away can be ignited by the explosion wave and that will cause knocking.
I was talking about the context of that engine (The Ford "Lima" OHC I4), which the single plug version does not have any knock issues, even at really high RPMs.
Same about the other post....110hp is more than obtainable on that engine without dual plug (removing the second plugs by just yanking the cables will still result in indentical figures on the dyno.
I don't see why you would want to run fiber optic cables. Why not just make every individual spark plug it's own laser unit designed to run off of a distributor and coil?
as i said, like a CoP setup except the coil isnt needed, (i guess you would call it a LoP) and neather is the distributor, it could just have a delay curcuit based off the FI system (which is all cpu controlled any way). x ammount of time after fuel is injected after takeing rpm into consideration fire the laser , its really no different than any car with modern electronic ignition, only your doing away with a high voltage coil, and replacing it with a fragile lazer...
