Hey all, I bought a larger WLAN antenna for my router but the signal is not improved. I'd appreciate an explanation, or even better suggestions on how to improve the signal.
I have a Zyxel P-2812HNU-F3 wireless router which looks like this:
http://www.telenor.no/privat/kundeservice/bredbandshjelp/zyxel_p2812/ . I use a pretty standard WPA2 2.4 Ghz setup, and there are few other wireless networks broadcasting in the area (perhaps 1-2).
I won't comment on Zyxel's naming schemes except to say there are apparently several similarly named models. The manual for a similar device without external antennas can be found here:ftp://ftp.zyxel.com/P-2812HNU-F3/user_guide/P-2812HNU-F3_1.0.pdf , I couldn't find the manual for my exact model.
I recently replaced one of the antennas you can see on the picture in the first link with the following antenna (directly on the router, without using the included cable):
http://www.konigelectronic.com/nl_nl/1116940
However, this didn't improve the signal. When I tried the larger antenna alone (without the remaining small antenna), the signal actually got worse. I suspect there is something I haven't understood here.
Thanks for any help!
