I'm working for a small charter school I'm in the process of upgrading all their infrastructure. This phase of the project requires WiFi coverage for the whole building, the building next door and the tent off to the side. Both buildings are 1 story separated by about 25'. The tent is about 150' from the wiring closet.
There is definitely some interferences between the mail budlinging and the tent, a class room and a few metal cabinets. There's not much i can do about those.
We currently have 2 Apple Airports that are not in use. The network will be about 6 eMac desktops with WiFi, 10 Latitude laptops and 4 more Macbooks.
I guess first off, are Airports and the Latitudes compatible? I imagine that they'll play nice, but I'm not %100 sure because I rarely play with any Apple stuff.
2nd, does anyone know the realistic range for an Airport?
3rd. Can you recommend a fairly nice WiFi router or AP? I'm pretty sure I can use the airport for the routing but it's not necessary. Either the Untangle server or a Linksys can also do the routing.
4th. is the range really decided by the size of the antennae or does the acutal router control the range? I know that with some 3rd party firmware you can increase the range but I'm trying to keep things stable and keep the warranty.
5th. Are repeaters a viable solution? I can't run any new wires. so if I have to extend the signal, will a repeater work? Does it have to be the same brand? If I use the Airport, do I have to buy more airports?
Thanks in Advance for any insight you can offer.
