EliteFantasy
- Oct 4, 2004
I closed my thread in laptops so I could post here to get more people to see.
On a Dell Inspiron 1000, I wanted to upgrade the RAM with a 512mb stick. I had it unplugged and took the battery out. I made sure to ground myself and the ONLY thing I did was unscrew the one screw to open the cover and slid and clicked the RAM into place, I did not even touch the other (more permanent) stick.
The computer started up amd went to the XP Pro loading screen. As it loads, the screen flashes blue *not the typical BSOD though* and restarts. The bios recognized the memory, but will not go any further. I took out the stick and it is still giving the same blue screen flash and restarts. The computer will not start in safe mode either.
What possibly happened and how can I fix this? It did not happen until I put the stick in so it must have been something that happened then. I have the XP disc (it was a clean install with a new XP Pro disc). I will try to recover if anyone thinks it will work (and wont lose the data). Any help is appreciated.
I looked at it some more and tried loading from the CD and got an error of the file NTSC.sys. Did I screw up the hard drive? Would using a magnetic scredriver (one I did not know it was) be enough to screw up a hard drive? It was on tiny screw on and off.
Thanks.
Thanks.
