stuntingalone
- Mar 10, 2007
I was wondering if anyone could see if two 120mm fans could fit side-by-side between the motherboard and the front of the case with the harddrive cage removed for a rad. I found a rad that is nearly the same size as the fan (no extra material over the mounting screws) and that is 280-ish mm long. I was looking at one at frys and i think it will fit, but i am not certain, so if you could check it out that would be great.
Thanks,
Nick
Thanks,
Nick
