L90D+ Use Digital or Analog
PeeMonkey
I just got my L90D+ today, I dont know if I should use the digital or analog cable. My video card is a Geforce 6800 GT. Not sure if that makes a difference. But analog gets 75hz while Digital gets 60hz, so which one?
O yea, I am going to use it for Gaming and all around stuff like internet browsing, etc..
if you an live without V-sync, then go with the digital cause the frames can then go past 60fps. But if you must have v-sync on or you want more than 60fps, then you'll want to have the analog so you can go to 75fps.
i find the way LCD's work with refresh rates compared to CRT's is much better. Try with the digital first, and see how you find it. VGA isnt too different, but DVI is always better.
:confused:
V-sync works with the DVI connection. I couldn't really tell a difference between the 60 fps and 75 fps of DVI vs. D-sub. Nor was there a discernable difference in image quality. The way that an LCD "refreshes", makes anything over 60 fps pretty unnoticable.
