KVM Switch Recommendation
Master_Pain
I need a KVM switch and am having trouble sorting through all of them.
Ports Needed:
2 monitors (3 preferable for upgrade purposes)
2 USB (3 preferable since my keyboard uses 2 USB ports, but I can just use a second mouse, not a huge deal, just a convenience thing)
Any recommendations?
What kind of monitor ports do you need? VGA, DVI, HDMI, Display Port?
I won't thread jack with my system needs, but I'm interested in a good one as well.
As far the most the basic KVM switch I see this Rosewill USB/D-Sub model for a reasonable price. It would suit my needs, but not sure the OP's.
DVI, HDMI, Displayport, Mini Displayport, it doesn't matter too much, I can just change the cables to meet the needs.
Though you didn't list it as an option, if you can go with VGA, the Rosewill one I linked above is working quite nicely for me (and for cheap).
I'm using it at work on a dual monitor setup. I've got my M6600 running on dual monitors A and B, and my personal laptop on monitor A.
Edit: But I believe you need to switch 2-3 monitors... Nevermind. Ignore me, just passing thru *whistles into the distance...
