Hi new build here. I have built a number of systems. Weird problem.
When I power on, the MB starts posting but it just FREEZES after the
mem test when it says OK. I can't hit the DEL key but I can ctl alt del
and it reboots. But then it doesn't do the MEM test after that. I am using
corsair memory, Sempron 3400+, and xp-90 HS. Thanks for your help
if you have any ideas.
regards
regards
