I am having trouble with my KRK 10s. When I turn it on, the light on back is red insted of green and I'm not sure what the problem is. When I turn on the SUB, even though light is red, my monitors still work and produce sound but no sound comes from the sub. Only thing I see in the manual is that if the LED is red then I should get it serviced.
My connection setup:
Mbox 3 outputs via 1/4' to SUB Balanced 1/4' Input
SUB ouput XLR to M-Audio BX8As Input.
Phase at 0
Low Pass 80hz
volume at 0db
Ground Lift set to Ground.
Phase at 0
Low Pass 80hz
volume at 0db
