ok so my koolance resevoir started to leak on me. its a pc2. well it started to leak at the lower return nipple. so i take it all apart and get a new brass fitting, drill and insert the brass fitting. now its been about 4 days and the thing is leaking all over. heres a pic. http://home.earthlink.net/~rondevu/bj/DSCN0591.JPG
ok now you see what im talking about. should i just use some plastic weld(epoxy for plastic) and spread it all over? i was planning on buying a via 1300 pump and a new resevoir, if i had to. what do you guys think? fixable? the other thing is the lid to the res is all messed up too, i guess i tightened it down a little too much. and its cracked on one corner. is it even worth the trouble? should i just wait and get the via and a new res? what res do you guys recommend? thanks
