$BangforThe$
- Nov 5, 2005
Has anyone using koolance aluminum Rad had problems with corrosion? If so were you using the koolance liquid?
The answer to this really entirely depends on what fluid you use. If you stick with the Koolance stuff you'll be fine. If you use any fluid spec'd for use in mixed metal water loops you'll be fine. If she's got clear topped water blocks and really wants to.... who cares? Its just money. Rejoice she's into it!$BangforThe$ said:OK . Has anyone used a copper block that is not gold plated and seen any problems. I have ten units out using the koolance system and they do have raw copper blocks in them
I just installed new coolant in a system I have had out for 2 years for a customer and there was no corrision to be found in the system . The reason I am asking is my wife is building a system and she wants to have the blocks gold plated . I think its a waste of money so thats why I am asking. The rad isn't Aluminum but she does have aluminum components in the loop.
WRONG.... if you don't use an approved fluid, this is what happens.Ctrl_Alt_Delete said:http://www.hardforum.com/showthread.php?t=1045300
$BangforThe$ said:I seen this before it looks to me like the Royal purple caused that problem.
dekard said:The answer to this really entirely depends on what fluid you use. If you stick with the Koolance stuff you'll be fine. If you use any fluid spec'd for use in mixed metal water loops you'll be fine. If she's got clear topped water blocks and really wants to.... who cares? Its just money. Rejoice she's into it!
