Keys wont work, please help!!
Zekenstein
Im at work and my boss was just closin a program and suddenly the only keys tht work are the windows key, caps lock, scroll lock... None of the functional keys like the letters or even enter key will work, additionally when clicking on the different icons they will be highlited and then you can continue clicking additional icons and they will also be highlighted. the computer is running on Windows 2000 and I'm wondering if this is a common problem or if anyone is familiar with any practical ways to fix it.
Sounds like your control key is stuck or something, try tapping the control keys a few times and see if that helps.
I ave te same problem, te key just rigt of te g isn't working... and my omepage is different tan it used to be....
I'm just playin with you:p
Scan for viruses and ad/sapyware... after, of course, trying a different keyboard.
