K8N Neo Plat Ethernet problems
jlee1
Hey Guys,
My roommate and I both have K8N Neo Platinums with AMD Athlon 64s. We've both had our computers spaz out randomly and not allow us to get IP addresses.
I built my computer first and it was perfect for the last month. Then today it randomly decided I could not get an IP address. I tried replacing the cable, the switch, the router, no router, the nforce drivers, and had a friend see if his laptop could use the same cable. All signs pointed to hardware failure. As a CS major, I've done a lot of shit like this before, and this was seriously the weirdest thing I'd ever seen.
Well, almost, because my roommate had the exact same problem on the first day he built his computer (basically the same spec as me: we both have MSI K8N Neo Platinum with AMD Athlon 64 3000+, 1GB DDR400 RAM, Geforce 6800, etc). In our room we have a comcast cable modem attached to a 10/100 Fast Ethernet switch. He plugs directly into the switch, and I have a Netgear MR814 router attached to the switch (all my computers use the router). When he couldn't get an IP, my laptop could using his connection. I played with the Windows settings (not really changing anything at all), and then after power cycling the switch and modem, it worked for him.
So I tried all that with my computer today with no luck. What is even weirder, is that I took my computer off the network, I couldn't even ping my router at 192.168.0.1. My router refused to give me an IP, and windows kept giving me the default private address shit. I tried removing the router from the picture, and even tried plugging directly into the cable modem with no avail.
Eventually, I've just given up and taken the old 10/100 PCI ethernet card from my old desktop and now it works perfectly using the router and switch from this card.
I feel like I shouldn't have to do this, considering I paid for a motherboard with a premium feature set including gigabit ethernet. I'm thinking perhaps this is a problem related to the motherboard or nforce3 250gb chipset, since my roommate and I both had the same issue.
Anybody else out there having these issues?
Thanks
i've had my board since the end of june with no problems, but i keep an eye on the official MSI forums. if you check there, there are A LOT of complaints about the ethernet on the board, amongst other problems. MSI Forums
Hm.
Odd.
Well, as a side question, do you know how to get the front usb/firewire ports working? I too have an Antec Sonata with the K8N Neo Plat. They don't work even though I hooked them up to the motherboard at JUSB and Jwhatever.
i had them working at some point, then i hooked up the DLED bracket and they stopped working. I remember seeing a thread about it, but can't remember if it was here or in the MSI forums. I don't even use the DLED bracket's USB ports, so I assume if I just unplug it's USB support the LEDs should work and my front ports would start working again. However I haven't gotten around to doing that yet.
Question for you: is your front audio port signal reversed? IE, does the left channel come out the front speaker and vice versa? I only have this problem on the front and not the back ports.
