K8N Neo plat 2
Filter
ok problem i'm having is this mb wich is the nf3 250 chipset is only seeing 131 gigs of my 200 gig drive. ive had this drvie on a nf 7s and it seen all 200 gigs. yes i know when you format it eats some of it up but not 70 gigs worth. in the bios it sees it as 200 gigs in the cpacity but winxp will only let me creat a partiton of 131 gigs and thers none extra.
any help?
im pretty sure winxp sp1 solves that problem but i may be wrong, also maybe you have system restore or something taking a lot of space?
Just create a partition of about 40 GB for now for your OS and other programs, the rest for music, files and stuff.. Once you get XP SP1 installed and reboot it should show the extra volume. Don't want to do that, just create the whole 131 GB as a single partition, then once the OS is installed it should show up as 200GB. I had the same thing with a 200GB Seagate drive. Once XP was installed no problem.
