JBOD Crashed
hainer36
Well the other day I was thinking, I had better change my 10TB JBOD array to something a little more backup friendly. And then last night it crashed
Does anyone have a good recovery program/method to get my info back
The hdd's were 2 WD 2TB greens, and 4 WD 1.5TB greens. Running on a rocketraid 2680 SAS raid card
Hopefully the drive that hosts the filesystem is still alive as that will be the only way you will be able to recover the other drives.
Try your usual suspects: GetDataBack, R-Studio, etc.
So since my controller says the drives are offline, would i have to plug them into the onboard sata connectors (obviously not initialize them) and just create a virtual raid in R-Studio?
If you have extra drives around i would create byte by byte images of each drive first, so incase you initialize one or something goes wrong you can put it back.
