i bought it off ebay and the seller said that its a Fujitsu MAU3147NC.
but the label on its states Worldisk and model no is MC03147SC800600X which i cant find anything on the web on it.
here's HD Tach benchmark of one of my hdd. Is the big dip at ard 15gb area a big problem?
Download some HD diagnostics and check for bad blocks.
might be a re-manufactured drive ?
Is this replicable across runs?
You appear to be capped by the SCSI bus, not the PCI bus. Have you got another cable you could use? What does the card report its "sync" as? Is there a terminator on the cable?
