is there a speedstepping for voltage?
ekuest
so i have my q6600 on an asus p5q pro stable at 3.6GHz. i have the voltage at 1.5125. id like to have it run at a lower voltage when it runs at a lower speed, aka when speedstepping is on. is that possible? is it a bad thing to have it at 1.5 all the time?
it should automatically lower the voltage as it drops the multiplier but some one will correct me if im wrong..
Yes, it dies automatically lower the voltage, but it has to be set to "AUTO" to lower when speedstep is on. And yes 1.5V is kinda high.
hm. i have it set manually. will it set itself that high automatically? i think it wouldnt before when i had it on auto and tried 3.6. temps are fine cuz its under water. wish i had one of those awesome-clocking Q6600s. mines just an average G0.
I about had a heart attack on your voltage until I saw you were water cooling.
Have you tried adjusting the other voltages and skew settings related to the CPU and chipset to see if you can get it stable at a lower CPU voltage?
Check out this post of mine to get a good idea of what the voltages, etc should probably be like for a
Q6600 on a P45 based board.
http://www.hardforum.com/showpost.php?p=1034665505&postcount=640
yeah i have no idea what any of those other settings do. wanna help me with my p5q pro? it looks like some of the settings are the same, but a lot are different. you may have gotten a better Q6600 than i did. it just crashed a few seconds ago with 1.5Vcore. not sure if it was temp or voltage related. ill try to get as close to your settings as i can and report back. :)
oh btw is that prime95 stable? if so then for how long did you test it?
also i think the vcore for my chip is 1.325V.
and actually none of those settings are the same. i have no idea what to change to get it to your clocks.
Yeah, you may not be able to get it as high as mine.. but I would think it should at least do 3.6 without too much trouble. The key is to find the best reference voltage settings for your processor.
When I first got my P45 based board it was a whole new world to me and took me a few days of researching and tinkering to get it this high.
The 65nm and 45nm processors require different reference voltages and from what I have found, most boards with the settings default to the 45nm processor ratios.
Here are a couple links that shoul help you, especially the XtremeSystems one... although they seem to be down right now.
http://www.xtremesystems.org/forums/showthread.php?t=202292
http://www.tomshardware.com/forum/240001-29-howto-overclock-quads-duals-guide
1.3750 is what i have with my q6600 and p5b deluxe, @ 3.2,
with my crappy cooler, i was never able to attain higher.
Curious, what voltage settings do you have for nbridge, sbridge, and ram?
